| stupid question of the day http://ducatipaso.org/forum/viewtopic.php?f=3&t=3207 |
| Author: | pasophist [ Sun Apr 12, 2009 1:00 am ] |
| Post subject: | stupid question of the day |
I have a split coolant reservior overflow tank. I want to do the fix described in the 907ie tech section. I cant find the photograph that I know is there. I've seen it before. Could someone please direct me to the pic? Thanks Sheldon |
| Author: | jcslocum [ Sun Apr 12, 2009 1:10 am ] |
| Post subject: | Re: stupid question of the day |
Fix in what way?? Weld the tank ot make it just an overflow?? check this link: viewtopic.php?f=3&t=3064 |
| Author: | pasophist [ Sun Apr 12, 2009 1:32 am ] |
Hi Jon. I did do a weld of sorts (didn't know there was a post on that) but I'm not confident it will hold to 13 psi so I figured the right thing to do is the do the de-pressurize the bottle trick using the Honda filler neck. That's the pic I want. Sheldon |
| Author: | 93IE [ Sun Apr 12, 2009 4:33 am ] |
I did the fix with the Honda part today. I bought a coolant neck for a CBR1000 on Ebay and it fit just fine using the hoses and clamps that came with it. It only took about an hour to install the neck. Busy day, I also replaced all the fuel lines, and coated the fuel tank with POR 15. I purchase the Napa Auto fuel pump and will install it after the POR 15 sets up |
| Author: | persempre907 [ Sun Apr 12, 2009 7:20 am ] |
What CBR 1000 MY? Since the 906/907 coolant tank is no more available, it's a good trick. Could you put some photo of the "new" tank fitted on the bike? Ciao |
| Author: | jcslocum [ Sun Apr 12, 2009 12:47 pm ] |
Sheldon, You avatar pic needs to be uploaded again and maybe put in your location? |
| Author: | pasophist [ Sun Apr 12, 2009 4:39 pm ] |
John I havent tried to use an Avatar yet. Will do so. Really need that picture though- the one of the Honda Coolant neck installed. Could you direct me to it or post it againn or PM me? Thanks Sheldon |
| Author: | ducbertus [ Sun Apr 12, 2009 5:50 pm ] |
when the coolant tank is welded properly it will hold. I did mine 3 years ago and still holds. the welding costed me only € 15 and an hour drive. ducbertus |
| Author: | jcslocum [ Mon Apr 13, 2009 11:14 am ] |
this is the olny info I have: http://www.frontiernet.net/~jcslocum/Du ... nk_Mod.pdf A pic on page 2 of the install. |
| Author: | 93IE [ Tue Apr 14, 2009 2:05 am ] |
Sheldon, I have some pics of the CBR 1000 coolant neck I just put on my bike. Not sure how to send them thru this site though. You can email me at xshelbyoner@hotmail.com and I'll send them to you. Preston |
| Author: | jcslocum [ Tue Apr 14, 2009 9:45 pm ] |
Preston, This are instruction on how to inset pictures into your post at the top of the 907 forum. |
| Author: | 93IE [ Thu Apr 16, 2009 3:28 am ] |
Sheldon. I got a coolant reservoir for a Kawasaki EX250 and it fits fine where the Ducati tank was. Two small brackets can be easily made to mount it to the original bracket behind the headlight. I should have it mounted tomorrow. Send me your email address again if you want pictures. I got it on ebay for $15 with shipping. This is a permanent fix . Preston |
