| It is currently Fri Apr 24, 2026 10:50 pm |
[ 1 post ] |
| Author | Message | |||
| Shelboss |
Joined: Wed Sep 06, 2006 12:00 am Posts: 101 Location: USA model: 907 I.E. year: 1991 |
| Top | ||||
[ 1 post ] |
Users browsing this forum: No registered users and 13 guests |
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum |
Then I brought it to a professional, who did a great job for $40. He said that the parts being welded need to be preheated with oxy-acteylene to within a few degrees of the melt temperature and then TIG welded. I then did a lot of band sawing, filing, and sanding to get a contoured look and as wide a pad on the ground as I could. I had to sand a little off the back surface to clear my exhaust. Overall the lean angle and stability are way better, not to mention it is easier to put down with my foot!
