| WANTED 1991 907 choke cable http://ducatipaso.org/forum/viewtopic.php?f=3&t=3259 |
| Author: | Heavy D [ Tue Apr 21, 2009 1:39 pm ] |
| Post subject: | WANTED 1991 907 choke cable |
Does any one know if anybody is making a replacement...Called BCM and they no longer can get it or have any. I called around to a few Guzzi shops etc. and no luck. A little help ! Thanks ! |
| Author: | jcslocum [ Wed Apr 22, 2009 8:25 pm ] |
| Post subject: | Re: WANTED 1991 907 choke cable |
It's a simple cab;e, so you could have it made or make it yourself. I have one for the Paso 750 made at a local bike shop. |
| Author: | Heavy D [ Thu Apr 23, 2009 11:22 pm ] |
I pulled the cable out and yes it looks simple but there are no bike shops anywhere near me. The closest is in Syracuse 5o miles from me. Ordering on line or having it shipped is my first try before taking trips and burning up gas... I've already tried the small engine shops to no avail. Thanks Dean |
| Author: | jcslocum [ Fri Apr 24, 2009 12:10 pm ] |
What is broken?? If the end has pulled off, get a lead split sinker and crimp it on. The cable is probably nothing special so go online and look for bike cables and order one. |
| Author: | Desmo_Demon [ Fri Apr 24, 2009 1:13 pm ] |
I think Motion Pro can remake just about any cable, and they probably have the specs for any OEM cable. I know I can still order throttle and choke cables for the Dellorto twin carb conversion for my Paso through them. Worse case is that you may have to send them your cable to duplicate it. http://motionpro.com/ |
