| Freeplay front sprocket? http://ducatipaso.org/forum/viewtopic.php?f=3&t=3309 |
| Author: | Tamburinifan [ Sun May 10, 2009 7:13 pm ] |
| Post subject: | Freeplay front sprocket? |
Is there any freeplay for the front sprocket to wiggle a little on the shaft? |
| Author: | jcslocum [ Mon May 11, 2009 1:31 am ] |
| Post subject: | Re: Freeplay front sprocket? |
Yes there is. The sprocket is a slip fit and the keeper holds it in place. |
| Author: | Tamburinifan [ Mon May 11, 2009 10:47 am ] |
Thx!
| Author: | Finnpaso [ Mon May 11, 2009 5:06 pm ] |
Check anyway axle, if there is any wear signs!
| Author: | Kurt [ Mon May 11, 2009 7:39 pm ] |
... and drill the two screws for lock wire while you have them out ... ... and install a "Desmo Times Case Saver Insert" from http://desmotimes.com/ |
| Author: | Tamburinifan [ Mon May 11, 2009 11:32 pm ] |
Axle no wear & Desmo Times case saver I have! |
| Author: | dtrides [ Tue Jun 23, 2009 11:49 pm ] |
Speaking of front sprockets, I just ordered a 14T front sprocket from Demo Times. The new sprocket has all the spacing on one side while the stock sprocket has a equal shoulder on both sides. I am worried about chain alignment . What are you guys doing?? |
