| speedo cable http://ducatipaso.org/forum/viewtopic.php?f=3&t=3337 |
| Author: | pasophist [ Wed May 20, 2009 4:54 pm ] |
| Post subject: | speedo cable |
What Ducati speedo cables are compatible with the 907ie? How long is it? Thanks Sheldon |
| Author: | higgy [ Wed May 20, 2009 8:48 pm ] |
| Post subject: | Re: speedo cable |
How long is it? Always with the personal info,heh Sheldon? Wassup with that? The answer 3 guys are standing on a bridge takin a pea 1st guys says, Man that water is cold! 2nd guy says Yea,and its deep too! 3rd guy says But it's muddy on the bottom! |
| Author: | pasophist [ Wed May 20, 2009 11:39 pm ] |
Very good Higgy- but I won't know how far away that bridge is from home or be sure to get to it with the fuel I have on board without a speedo/odo cable, will I? Gotta go pee myself now. Sock's too tight. |
| Author: | h1a [ Thu May 21, 2009 4:13 pm ] |
Bought a new from my dealer last summer, the cable is 85cm, part# 40310011A |
| Author: | jetboy [ Thu May 21, 2009 8:16 pm ] |
if your casing is still good you can get a universal kit from places like motionpro - then you just cut it and crimp to the size you need. I actually changed out my speedo to an aftermarket job and used a kawasaki kz casing - which was just about exactly the right length- and the motionpro cable-- so far so good. |
