| Battery Problem http://ducatipaso.org/forum/viewtopic.php?f=3&t=359 |
| Author: | KillerB [ Tue May 03, 2005 7:12 pm ] |
| Post subject: | Battery Problem |
I have a '91 907 that seems to have a battery draining problem. After having replaced the battery it still gets weak after a week or two. I notice that occasionally the battery light will come on. Has anyone had a similar problem? Any help is appreciated. Regards, B |
| Author: | wiggs [ Tue May 03, 2005 9:20 pm ] |
| Post subject: | |
hi killer, sorry i don't have any real good advice for you. i've had the battery tender off my 907 for a few weeks now and am afraid to see if it will start.i think the best thing both of us can do is keep a battery tender on them most of their idle time. now i just need to take my own advice. |
| Author: | redpaso [ Tue May 03, 2005 11:49 pm ] |
| Post subject: | |
Check the voltage regulator, if this is faulty it may be draining the battery as it was on my 906, I found that out after thinking my battery was stuffed & spending $100 to replace it only to find it was flat again a month later, it would often start first go but as the battery was not charging if she stopped while warming up the only way to restart was to jump start the old girl. On a long ride I backed off the throttle into a tight turn & she died & would not restart, I had to get the bike shop to retreive me & Lady Paso. That was when I found out the real problem. Check it out. If it is the problem the regulator is not strong & should not be replaced with the original ducati item (the Ducati shop told me that) they can be reconditioned but it is easier to replace with a japanese unit that is made for Ducati's but did require some rewiring on the 906. I think all these parts are tehsame on the 907. I hope yoyu sort it soon. :thumbup: |
| Author: | ynot [ Wed May 04, 2005 7:10 am ] |
| Post subject: | |
I changed regulator twice- but it´s shit! Try the regulator from http://www.silenthektik.com :funny: |
| Author: | KillerB [ Wed May 04, 2005 12:36 pm ] |
| Post subject: | |
Thanks for the advice. I may give that old regulator the boot and see if it cures my problem. |
| Author: | Finnpaso [ Wed May 04, 2005 7:56 pm ] |
| Post subject: | |
| Author: | KillerB [ Wed May 04, 2005 8:17 pm ] |
| Post subject: | |
