It is currently Tue Apr 28, 2026 8:47 am
 Post subject: Delayed starting
PostPosted: Fri Sep 11, 2009 6:25 am
'92 907IE. When I hit the starter button, the bike does nothing for about 1 second then gives a crank and then second crank right away and bike always starts. Just seems to be a delay in starting when starter switch is engaged. Sprang gears have been replaced. Is there a starter relay problem here? On my Aprilia we all went to a Kawasaki starter relay which put out more power and cured the problem. Is there such a thing for this Duc? If so need a maker and part number. I don't believe this to be a battery problem but I won't rule out anything. Thanks for the help.
Dennis
 Post subject: Re: Delayed starting
PostPosted: Fri Sep 11, 2009 1:49 pm
I have the same problem intermittently. I usually put it in gear and rock the motor to get it off of the compression stroke and it turns over freely after that.
Preston
PostPosted: Fri Sep 11, 2009 9:08 pm
Very definitely is the earthing problem.
viewtopic.php?f=3&t=3140
PostPosted: Sun Sep 13, 2009 12:03 am
this has happened on both my 907's.So far all i have done is fully charge batterys and motor turns over as soon as hit starter.
