| Delayed starting http://ducatipaso.org/forum/viewtopic.php?f=3&t=3593 |
| Author: | dennist [ Fri Sep 11, 2009 6:25 am ] |
| Post subject: | Delayed starting |
'92 907IE. When I hit the starter button, the bike does nothing for about 1 second then gives a crank and then second crank right away and bike always starts. Just seems to be a delay in starting when starter switch is engaged. Sprang gears have been replaced. Is there a starter relay problem here? On my Aprilia we all went to a Kawasaki starter relay which put out more power and cured the problem. Is there such a thing for this Duc? If so need a maker and part number. I don't believe this to be a battery problem but I won't rule out anything. Thanks for the help. Dennis |
| Author: | 93IE [ Fri Sep 11, 2009 1:49 pm ] |
| Post subject: | Re: Delayed starting |
I have the same problem intermittently. I usually put it in gear and rock the motor to get it off of the compression stroke and it turns over freely after that. Preston |
| Author: | JWilliam [ Fri Sep 11, 2009 9:08 pm ] |
Very definitely is the earthing problem. viewtopic.php?f=3&t=3140 |
| Author: | tewsy [ Sun Sep 13, 2009 12:03 am ] |
this has happened on both my 907's.So far all i have done is fully charge batterys and motor turns over as soon as hit starter. |
