It is currently Sat Apr 25, 2026 12:45 am
 Post subject: Dyna Coils
PostPosted: Wed Sep 23, 2009 12:17 am
I am thinking of replacing my ignition coils with Dyna coils. I've read where the 900SS and Monsters are being sold 5ohm coils, but others 3ohm coils. Does anyone know which coils to use on the 907ie?
I've heard they improve starting and performance.
Preston
 Post subject: Re: Dyna Coils
PostPosted: Wed Sep 23, 2009 11:02 pm
Either will work just fine,you will only have issues if you go below 3ohms. I went for the 3ohms on my 906 and they work great
PostPosted: Mon Sep 28, 2009 12:37 pm
hi,
are you sure this will work on the 907i? its fuel injected and uses the latter Generation coils.
While 906 is carb and is easy swap.
kalli
PostPosted: Mon Sep 28, 2009 11:38 pm
I guess I could always ohm out my exisiting coils to see what they are.
Preston
