| What chain exactly?lso http://ducatipaso.org/forum/viewtopic.php?f=3&t=3683 |
| Author: | Shatten [ Mon Oct 26, 2009 8:06 pm ] |
| Post subject: | What chain exactly?lso |
Hey Guys, I'm trying to buy a new chain for my 91 907 but I cant find exactly what chain it is that I need. I know its supposed to be a 520 but all the chains I see are 520 x (insert #). Is it 520 x100? 120? Also the site says that the 520 chain is rated for a 250cc engine and that certainly isn't right. Thanks in advance. |
| Author: | paso750 [ Mon Oct 26, 2009 10:03 pm ] |
| Post subject: | Re: What chain exactly?lso |
520x108 (chain links) You can fit a 520 chain also on a 250 or 125cc, but that doesn`t mean that`s the max the chain is rated for. G. |
| Author: | Finnpaso [ Tue Oct 27, 2009 2:52 pm ] |
Probably "G man" mean, that IF you have normal size sprockets, so check them still before you buy new chain.... U can also count amount of links very easily from old chain.... its 520 surely, but U can choose now o-ring, or x-ring chain....
| Author: | paso750 [ Tue Oct 27, 2009 3:05 pm ] |
exactly, assuming he`s using original/standard sprockets. However normally if you use a rear sprocket with 1 or 2 teeth more you still can use the original chain size and don`t need a longer one (yet). |
| Author: | 93IE [ Tue Oct 27, 2009 11:38 pm ] |
So how many teeth are normally on the rear sprocket? Mine has 37, but I'm sure a 40 would really give it grreat low end power, but I wonder how it would effect cruising at 75 mph? |
| Author: | Tamburinifan [ Wed Oct 28, 2009 1:50 am ] |
15/39 standard gearing. I run 14/40. 4000RPM in 5th/100km/h, 5k/120/5th. 6th still overdrive gear, I like it. & 108 fits this gearing. |
| Author: | Finnpaso [ Wed Oct 28, 2009 4:39 am ] |
I use 15 / 46 combo, as i dont need top speed so much...happy to acceleration... In my case original chain is too short... |
| Author: | injected [ Thu Oct 29, 2009 6:17 pm ] |
The rule is two links added/removed from the chain for every four teeth up or down on the sprocket. |
