| adjusting clutch biting point ?? http://ducatipaso.org/forum/viewtopic.php?f=3&t=3746 |
| Author: | holla [ Sat Nov 21, 2009 12:50 pm ] |
| Post subject: | adjusting clutch biting point ?? |
Hi all, My 907 had a recent new clutch fitted before i bought it but the biting point is very close to the bars, this makes it tricky when changing down the gears as you slow down. How can i adjust this ? Thanks |
| Author: | injected [ Sat Nov 21, 2009 1:19 pm ] |
| Post subject: | Re: adjusting clutch biting point ?? |
It's not designed to be adjustable, but you can try a) bleeding the clutch line b) if that doesn't help, remove the clutch pressure plate and put a small ball bearing inside the pressure plate bearing cup, ie so it lengthens the pushrod. One or both of the above will work no probs. Failing that you could fit a bigger bore master cylinder (eg from a later bike). Will also fix the problem. |
| Author: | ducbertus [ Sat Nov 21, 2009 5:57 pm ] |
there should be a little screw in the lever (Allen 3) or you can buy a more modern lever, which has an excenter to adjust the biting point. Ducbertus |
| Author: | holla [ Sat Nov 21, 2009 6:06 pm ] |
Thanks guys, I had adjusted the screw in the lever but it wasnt much better. I bled the clutch and its much better now, The fluid was black and i got quite a bit of air out of it. I was going to go out on it to see if its a lot better but its P!55*ng it down now Maybe tomorrow
| Author: | persempre907 [ Sat Nov 21, 2009 6:41 pm ] |
Remember to do a very accurate bleeding work. If not, you'll have many problem to find the neutral during the ride. Ciao |
