Samco Hoses http://ducatipaso.org/forum/viewtopic.php?f=3&t=3798 |
Author: | blazing928 [ Mon Dec 14, 2009 7:48 pm ] |
Post subject: | Samco Hoses |
Hi, I have searched about Samco hoses and there has not been a definitive answer if the 851 will rplace most of the hoses. What about the ST2 set, there is no picture on the site, http://www.samcosport.com/row/bike_kits.asp?make=Ducati Anyone got further information before I try? cheers |
Author: | englishstiv [ Mon Dec 14, 2009 10:10 pm ] |
Post subject: | Re: Samco Hoses |
I contacted them direct about a year ago and eventually got a reply, the result of which was they do not do a full set however if you vistied one of there main suppliers (that was here in the Uk to me) and took the Paso set to compare/match they may be able to assist. They also would not help when I even offered to send set direct to them and infact did not seem that interested in helping further ![]() As someone reminded me they are really there to support the race circuit set so if I want a set I will need to do all the donkey work and additional cost trying different sets to make a full matching set. Let me know if you have any better luck because they are lush. |
Author: | blazing928 [ Tue Dec 15, 2009 4:25 am ] |
After a fair bit of running around today , I think the best way is to fabricate an alloy or S/S piece for the two hoses that come off the main line, [a double' TT '] and also an elbow with a outlet to the coolant tank. Then buy what ever elbows and straight pieces and join it all up, maybe also using straight alloy pieces, like a race bike set up. Samco makes a flex hose that doesn't collapse so that may do some of the shorter lenghts. I have made up my mind to do this , so I will let you know the outcome! |
