ducatipaso.org
http://ducatipaso.org/forum/
Rear spring
http://ducatipaso.org/forum/viewtopic.php?f=3&t=3812
Author:  Tamburinifan [ Wed Dec 23, 2009 1:08 am ]
Post subject:  Rear spring
Got some info about the Öhlins shock f a 750 Paso fr horses mouth (Öhlins, Sweden).
Original 42Nm, +90kg rider 45Nm.
Spring should have 25mm preload.
I`ve ridden a 750 w original, restored Öhlins.
Seemed soft but worked really OK.
My question,
why the soft spring?
Is the linkage on a Paso so special?
All other springs is about 90-110NM, on Hyper Ducs round 70 :?:
Wondering cause I`ve bought a Penske f a 750Paso.
Author:  Finnpaso [ Wed Dec 23, 2009 7:57 pm ]
Post subject:  Re: Rear spring etc
I am wondering same thing every time i push down my 750 Paso grab handle in my garage, as its much softer compared to 907IE original Marzhocci unit... I feel also very comfortable that Öhlins in my 750 Paso, but i drive it alone allways without so much weight(i am about 78Kg's) and with my 907IE i carry near allways 2 sidebags with full of stuff and it feels also good with Marzhocci Duo remoto unit... I have installed Öhlins(from 750 Paso) to my one 907IE, but havent tested yet, sorry. As i know, all rear linkages are same in 750 Paso and 907IE :) At least they look identical, but havent check from microfilm!
Author:  Tamburinifan [ Fri Jan 01, 2010 1:38 am ]
So,
anyone know what rate the standard spring is?
& f a 95kg rider?
Author:  injected [ Tue Jan 05, 2010 3:04 pm ]
I believe 9.0kg/mm is standard on the 907.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
