ducatipaso.org
http://ducatipaso.org/forum/
M1r forks dimentions
http://ducatipaso.org/forum/viewtopic.php?f=3&t=3836
Author:  lofty 36 [ Wed Jan 06, 2010 11:07 am ]
Post subject:  M1r forks dimentions
HI Guys
Could someone give me the messurement from the bottom of the the lower fork tube to the first bolt hole for the brake caluper for the 907
The reason being as i have come across a pair and some parts but Not sure if they are for a 300 rotor disc.
Correct me if I'm wrong but i thought M1rs forks came with different bolt hole hights for the, 907,851 that have rotor discs , 300 and 320
Oh and if anyone is after bottom fork tubes i have a source that has a few lying around But of course i'm in first.
The newbe
Peter
Author:  englishstiv [ Wed Jan 06, 2010 1:30 pm ]
Post subject:  Re: M1r forks dimentions
BUMP............I have sent you a pm. :thumbup:
Author:  OzDuck [ Wed Jan 06, 2010 6:32 pm ]
Hi Peter
For the M1R forks with 300mm discs it is approx 134mm from bottom of fork to centre of lower caliper mounting hole.
For the M1R forks with 320mm discs it is approx 144mm
Regards
Joe
Page 1 of 1 All times are UTC
http://www.phpbb.com/
