Guide bushings on 907 ie M1R forks http://ducatipaso.org/forum/viewtopic.php?f=3&t=3889 |
Page 2 of 2 |
Author: | JoKing [ Fri Apr 13, 2012 6:36 pm ] |
Post subject: | Re: Guide bushings on 907 ie M1R forks |
Another source for M1R-Parts: http://www.laverda-paradies.de/shop/cat ... 000&chp=60 |
Author: | paso750 [ Thu Sep 03, 2015 11:58 am ] |
does someone have the dimensions of the upper bushes? The part number of the P750/906 bushes is different and I wonder why. I would assume the parts would be the same. In case they are another option for the bushes would be the Guzzi part number 30530520 used on: MG 1100 Sport (carbed) , 1994 - 1996 MG 1100 Sport carbed , 1994 - 1996 MG Daytona , 1991 - 1995 MG Quota , 1992 - 1997 MG Quota ES `99-`01 , 1999 - 2001 |
Author: | ducbertus [ Thu Sep 03, 2015 8:35 pm ] |
Hi Gert, I've a set of new BMW K1100 bushes laying around, waiting to be mounted. saterday I'll measure them up for you. they ment to go in a M1R of a '91 907 Bertus |
Author: | ducbertus [ Sat Sep 19, 2015 11:31 am ] |
Hi, finally have the bushes at hand. these are ment for a Beemer K1100, but should fit the M1R fork from a 907 as well upper bushing:#nr: 31 42 2 310 347 Ø outside ± 44.55 mm; height: 19.8 mm lower bushing: #nr: 31 42 2 310 346 Ø outside ± 41.60 mm: height: 15 mm regards, Bertus |
Page 2 of 2 | All times are UTC |
