It is currently Wed Oct 01, 2025 7:37 am
[ 2 posts ] |
Author |
blazing928
Post subject: Coil wiring for elec upgrade on 907 Posted: Mon Jul 12, 2010 4:26 am |
Joined: Tue Sep 15, 2009 4:08 am Posts: 222 Location: Melbourne Vic, Australia
Greetings I was going to do the coil wire upgrade and was following the various writings on the subject for 750s and 906s.
Of Course the 907 has different coloured wires.
Now one wire goes to earth some where back in the loom, so thats Ok.
The other wire;
Is it OK to just splice the relays into the + wire? I am guessing it won't affect the ECU or any other electronic bits. This would mean cutting the wire before it disappers into the main wiring loom.
Would any one also recommend cutting the earth wires and doing a new earth point closer to the coils [and using a thicker wire]?
I have done the starter upgrrade [4ga wire] and that hass been a great sucess, but sometimes it still starts a bit poorly, backfires, one cylinder etc, so I am hoping the coil upgrade will cure it. ta nigel
_________________ Nigel
91 907IE - full restoration 91 907IE Red, Wilbers, Staintune Conti, Corbin, MPL Slipper,Ceramic exhaust Lambretta LI150 S3 87 928S4
Top |
blazing928
Post subject: Re: Coil wiring for elec upgrade on 907 Posted: Sun Jul 25, 2010 12:06 pm |
did I answer my own question??????//
I had a thought about the electronic ignition, does the ECU send a signal to the coil as needed or is the power always on. If its a pulse, would a relay react fast enough?
Top |
[ 2 posts ] |
Users browsing this forum: No registered users and 7 guests |
