| 907 choke lever assembly needed http://ducatipaso.org/forum/viewtopic.php?f=3&t=4109 |
| Author: | holla [ Sat May 29, 2010 1:26 pm ] |
| Post subject: | 907 choke lever assembly needed |
Hi all, I was refitting my clutch master cylinder on my 907 this morning after having fitted a rebuild kit to it and on re-assembly i somehow managed to snap the 90 degree bend off the choke assembly The round disk with the "choke" writing on is ok its the bit that fastens on to the master cylinder with 2 little screws that i need. Anyone breaking/ parting out a bike and have this part ? I will pay you whatever you want just to get her back together again. By the way is it the same choke set up on paso's and 906's ?? Thanks |
| Author: | Finnpaso [ Sat May 29, 2010 3:33 pm ] |
| Post subject: | Re: 907 choke lever assembly needed |
Remembering, that also early Monster(and maybe SS) use same choke lever system, so it should not be so difficult to find used one cheaply from markets... |
| Author: | holla [ Sat May 29, 2010 6:04 pm ] |
Thanks Finnpaso, I saw one on ebay from greece with a buy it now, as i was'nt sure if they were difficult to get hold of or not, i bought it. Its from a 750 paso and looks the same from the picture, I'm just hoping it is the same when it arrives. I'll keep you posted unless anyone can confirm they are the same, thanks again. |
| Author: | Tamburinifan [ Sun May 30, 2010 1:05 am ] |
+1 on finnpasos advice. |
| Author: | persempre907 [ Sun May 30, 2010 1:12 pm ] |
Really, I bought a new choke lever from Ducati dealer (the red written of mine was faded ).I paid it 6 or 7 Euros, I can't well remember. As Antti said, the same lever has been fitted on many Italian bikes of that age, so it's easy to find it. Ciao |
| Author: | holla [ Mon May 31, 2010 2:31 pm ] |
Thanks persempre907. I'll have a look into it, Its not the choke lever i need its the bit it fastens to that screws to the clutch cylinder. |
| Author: | persempre907 [ Tue Jun 01, 2010 6:47 pm ] |
| Author: | pasolloyd [ Fri Jun 11, 2010 2:56 am ] |
I have used the current model of the Domino choke lever as supplied originally on the 907: The only diference is that you need longer screws for mounting to the clutch master cyl than the stock lever and it actually rotates toward you to apply the choke. Otherwise it is a direct fit. It is Domino #2903.86 and is available from: Allens Performance Ltd Unit B9 Moorbridge Road Bingham Notts NG13 8GG Tel: 01949 836733 Fax: 01949 836734 |
