| Whats this ? Seal or Bearing !!! http://ducatipaso.org/forum/viewtopic.php?f=3&t=4144 |
| Author: | Bomber [ Fri Jun 11, 2010 7:23 pm ] |
| Post subject: | Whats this ? Seal or Bearing !!! |
This is a picture of the shaft that the two cam belt pulleys are on.(92 907IE) Does any one know if the round black part around the shaft is a oil seal which can be easily replaced or is it a bearing cover ? I have a small oil leak which i think is from this shaft Cheers Bomber |
| Author: | du907 [ Fri Jun 11, 2010 9:30 pm ] |
| Post subject: | Re: Whats this ? Seal or Bearing !!! |
It is a seal that can be replaced from the outside. My 907 leaked there after a shop rebuilt my engine. They said they didn't replace that seal and sure enough it started leaking. I took the bike back and they replaced the seal while I waited. It took them about two hours. I think they may have drilled a hole then used a sheet metal screw in the hole then pulled on the screw to get it out. du907 |
| Author: | ducbertus [ Fri Jun 11, 2010 10:54 pm ] |
the seal has a metal kind of cup inside. when you insert a wood or chipboard screw you can pull it out and replace without major disassembly. or drive a screwdriver behind the seal and lever out the seal. good luck, Bertus |
| Author: | Tamburinifan [ Sat Jun 12, 2010 12:12 am ] |
It is a seal. |
| Author: | Bomber [ Sat Jun 12, 2010 6:47 am ] |
Thanks Guys, Just the information I needed, will attempt to remove the seal by the screw method Regards Bomber |
