907 Ignition keys http://ducatipaso.org/forum/viewtopic.php?f=3&t=4173 |
Author: | Timbo851 [ Mon Jun 28, 2010 2:17 am ] |
Post subject: | 907 Ignition keys |
Hello all Can anyone help-Ive lost my keys to my 907 after showing her at a classic bike show in April cant find them anywhere.Does anyone know how I can get replacements,do I have to dismantle the ignition barrel to find a key number??? or what really stuck please help. ![]() Many thanks Timbo |
Author: | riascns [ Tue Jun 29, 2010 9:13 pm ] |
Post subject: | Re: 907 Ignition keys |
Have you tried your local Ducati dealer? For car keys, the local main dealer can order a set once you can prove ownership via redisteration document and give them an engine and chassis number. May be worth a try. |
Author: | Timbo851 [ Tue Jun 29, 2010 9:47 pm ] |
Mate thanks for reply-have done given in both engine and chasis numbers but were talking about Ducati here they dont exactly have the best after sales back up.Have removed ignition unit and by the looks of it a triple heart by pass op seems easier to get at !!!! ![]() Will continue to try and sort it. ![]() ![]() Thanks Timbo |
Author: | riascns [ Wed Jun 30, 2010 8:45 am ] |
I remember seeing a while back a parts interchange list that listed an alternative ignition switch for the paso. The list is at http://www.motomate.net/parts/ And the switch is: Paso ignition switch - Gilera 125 SP01 Looking at the forums here, it appears that all paso models have the same switch viewtopic.php?f=3&t=3050&start=30 Sean |
Author: | persempre907 [ Wed Jun 30, 2010 12:26 pm ] |
The barrels aren't the same on all Pasos: as G. stated, the difference is the height of the upper barrel. 39mm on the 907ie lock and 52mm on the P750/906 lock. (The connector on all is the square one with 6 round pins in it). Dismantle your barrel and make do some new keys by a good craftsman. Ciao ![]() ![]() ![]() |
Author: | Timbo851 [ Thu Jul 08, 2010 9:09 pm ] |
Have managed to sort my problem over lost keys-stripped unit down no number on barrel but local auto locksmith made me two keys all for £21.50, Made up bike looks great sounds brill watch out the roads of Wirral here I come Many thanks Timbo ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | englishstiv [ Thu Jul 08, 2010 9:43 pm ] |
Look forward to seeing it out and about when I'm (sadly) in my van. ![]() |
Author: | kgreenlaw [ Tue Aug 31, 2010 5:00 am ] |
Have the locksmith look up a Fiat Uno key - mine found one that was correct. The easiest barrel to take off the bike and the least risky for the locksmith to disassemble is probably the helmet lock but the ignition isn't that hard to get off either. Good luck; may the original key show up the day after like mine did... --Ken |
Author: | higgy [ Tue Aug 31, 2010 10:11 am ] |
http://www.keys4classics.com/ |
Author: | 907pasonut [ Wed Sep 08, 2010 10:14 am ] |
Author: | 907pasonut [ Tue Sep 14, 2010 10:51 am ] |
Author: | persempre907 [ Tue Sep 14, 2010 8:59 pm ] |
You're lucky. The MY '91 and '92 have different keys. At least, on my bikes it's so ![]() ![]() ![]() Ciao |
Author: | Antzo [ Fri Mar 18, 2011 1:55 pm ] |
I was wondering do the original 907 keys write ducati on them ? Mine write ZADI made in Italy are these original or aftermarket? thanks |
Author: | 907pasonut [ Fri Mar 18, 2011 2:06 pm ] |
the original 907 keys have ZADI written on them |
Author: | Antzo [ Fri Mar 18, 2011 2:12 pm ] |
![]() thanks for the info!!!! |
