It is currently Fri May 01, 2026 12:38 am
 Post subject: 907 Brake Pads
PostPosted: Mon Sep 13, 2010 6:30 pm
I have a late 907 with dual piston brembo calipers.
My question is how do you change the pads?
There are no split pins, screw in pins like on other bikes. Is it a question of pulling them out with a vice grip?
907IE
Paso 750
CB 900FD
KX 500
KTM 500 with Zabel 700 Engine
zx10
Mobylette Cady
 Post subject: Re: 907 Brake Pads
PostPosted: Mon Sep 13, 2010 7:13 pm
Check this site. Download the spring 2010 edition pdf file. It has a step by step on front brake pad removal. It's not that hard.
http://usdesmo.com/leanings/Leanings_2010_1_Spring.pdf
Good luck.
du907
PostPosted: Mon Sep 13, 2010 8:04 pm
Thanks,
Just what I needed as I had missed that the r clips were on the inside!
What a fantastic club magazine. Better than many of the commercial publications available. Certainly a favourite place to visit again.
Sean
907IE
Paso 750
CB 900FD
KX 500
zx10
Mobylette Cady
