It is currently Tue Jul 14, 2026 4:48 am
[ 10 posts ] |
| Author |
jim
Post subject: cush drive bushings Posted: Sat Jun 04, 2005 8:12 pm |
| Top |
jomo
Post subject: Posted: Mon Jun 06, 2005 12:01 pm |
Joined: Sun Jul 18, 2004 12:00 am Posts: 127 Location: Australia
jim,
How many K's on the bike?
Are you sure your chain isn't too tight?
Put it on the centre stand and rotate the wheel forward a few turns, if it looks irregular, get back to us. Run it backwards, if it looks irregular, get back to us.
If you had twin carbs, I may have suggested something like carby balance....but I suppose that isn't going to happen with fuel injection!?
_________________ Brake late & brake hard, jomo
Paso 906 Blue Paso 906 Silver Bultaco Metralla GT370 Custom Bultaco Metralla GT250 Bultaco Frontera 250 Mk.9 Suzuki RMX250
| Top |
jim
Post subject: Posted: Mon Jun 06, 2005 8:31 pm |
Thanks for the reply, jomo.
My bike's got 28K miles on it. No, the chain is almost new, properly adjusted and not too tight. The front and rear sprockets are almost new, also, being replaced at the same time as the chain. Nothing seems out of the ordinary other than the play between wheel and sprocket carrier, and the snatchiness definitely seems to be coming from the driveline.
Jim
| Top |
Apex
Post subject: Posted: Tue Jun 07, 2005 9:37 pm |
| Top |
jim
Post subject: Posted: Mon Jun 13, 2005 7:57 am |
Thanks Apex,
The play that I have between sprocket and wheel is not lateral, but linear. In other words, the sprocket does rotate slightly when the wheel is still. This is why I suspect either worn cush bushings or worn sprocket carrier studs, but as i said, the cush bushings nor the studs look particularly worn to me. I suppose, however, that it must be one or the other unless I'm overlooking something. What do you think?
Jim
| Top |
Apex
Post subject: Posted: Mon Jun 13, 2005 7:31 pm |
Jim--
I will check my 907 to see if there is any play. I also have a spare wheel and sprocket assy off the bike so I can check it too. I don't know how many miles are on the spare but if it is tight we will know you have a wear issue.
Jeff
| Top |
Apex
Post subject: Posted: Thu Jun 23, 2005 1:18 pm |
Well I finally checked both my bike and my spare wheel/sprocket and there is no play. The bike has 21,000 miles on it and the mileage on the spare is unknown, although it came off a well-worn bike. From the design of the cush drive, it's hard to see how you could get much play, but anything is possible. Did you check how well the sprocket is affixed to the carrier--I am sure you did but I thought I'd ask.
Jeff
| Top |
krakan
Post subject: Posted: Thu Jun 23, 2005 7:57 pm |
Hi jim. My bike had the same problem with a slight slack between the sprocket carrier studs and the cush bushings. The
rubber didn´t look worn either. I first noticed the problem
when I was out riding last fall. I lokated a small slack (can one
call it that?? sorry not so familiar in written english. Must write more posts I think.) and I removed the rubber bushings then covered
them with hot glue from my glue gun and reinstalled them, I
wasn´t sure if it worked. I didn´t get a chance to ride again
until this spring but to my surprise no more slack!!! I read
about this fix in an old ex. of Motorcyklist and the dude had
the same problem on a zx kwak. It worked fine. Krakan
| Top |
jim
Post subject: Posted: Sat Jun 25, 2005 9:18 am |
| Top |
Apex
Post subject: Posted: Sat Jun 25, 2005 6:59 pm |
| Top |
[ 10 posts ] |
Users browsing this forum: No registered users and 4 guests |
