ducatipaso.org • View topic - is a startmotor of a S2 the same as one of the 907?
It is currently Sun Sep 28, 2025 9:59 pm
 Post subject: is a startmotor of a S2 the same as one of the 907?
PostPosted: Sun Oct 24, 2010 6:24 pm
I have a startmotor of a ST2 laying around and want to check it, do the mod of earthing the - brush by a decent cable.
just need to be sure that they are the same. so I can swap the starter motors in one action.
Bertus
 Post subject: Re: is a startmotor of a S2 the same as one of the 907?
PostPosted: Mon Oct 25, 2010 3:49 pm
I think, that if mechanical measurements are same, then You can use it. There cant be big difference with needeed current, so that electrical part you can forget. I havent look mine closer, but i quess, they are exact samekind, maybe from another manuafacturer, but that is not problem at all.... :smoke:
PostPosted: Mon Oct 25, 2010 9:11 pm
Hi Annti,
I knew you would post a reply. To be honest, I saw an article about startmotors where the writer changed the standard starter, which contains 2 brushes into 4 brushes. this doubles the torq of the starter and has a dramatic improvement on the starting of the big twins. That's what I aiming for.
regards, Bertus
PostPosted: Mon Oct 25, 2010 11:36 pm
PostPosted: Tue Oct 26, 2010 4:30 pm
Hi tamburinifan,
it seems that there is a possibility to use a brush plate with already 4 brushes.
not every 4-brush plate will fit. some brush plates have the spring to far out, causing short cicuit.
so far I'vent any links to some articles about this subject sofar.
Bertus
PostPosted: Thu Oct 28, 2010 12:21 am
Friend of mine tried to adapt similar 4 brushes to st engine, no luck.
I bought one, too. Sould give more ooomphh f starter
but not so easy to do even if that was almost the same.
But I´m listening.... ;)
PostPosted: Fri Nov 12, 2010 2:12 pm
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
