| Dumb Question http://ducatipaso.org/forum/viewtopic.php?f=3&t=4347 |
| Author: | 2vtwin [ Mon Oct 04, 2010 4:43 pm ] |
| Post subject: | Dumb Question |
Purchsing a 907ie, noticed it does not have the Center Stand, only the damn spring loaded side(jiffy) stand. Was the center stand an option? Thanks - Gene |
| Author: | Finnpaso [ Mon Oct 04, 2010 6:07 pm ] |
| Post subject: | Re: Dumb Question |
NOT option, as EVERY 907IE had such from factory. Some are for sale sometimes in Ebay and if You know good welder, he can also do such to You. You can also easily modifie side stand such way, that it is not "automatic" anymore. Put anotherkind screw(shorter) to it and its ok then. That curved plate (holds spring) is "passing" that holder screw then. Sorry, i dont know, what "jiffy" means....
| Author: | higgy [ Mon Oct 04, 2010 6:22 pm ] |
Most likely it was removed,either for a non standard exhaust installation or some Psuedo racer thinkin he needed more ground clearance
| Author: | Finnpaso [ Tue Oct 05, 2010 6:05 pm ] |
It hits sometimes to surface in race track, i see also scratches in my both 907's.
| Author: | persempre907 [ Tue Oct 05, 2010 6:19 pm ] |
| Author: | Mc tool [ Wed Oct 06, 2010 4:48 am ] |
Nah , me neither , What are you doing Antti ( I bet he is one of the dudesons )
| Author: | higgy [ Thu Oct 07, 2010 12:36 am ] |
I confess to scars on both knees,but no marks on my center stand, if the stand is draggin the wheels will soon be off the ground and that can never end well
| Author: | du907 [ Thu Oct 07, 2010 3:01 am ] |
Somebody removed the center stand. To fix the side stand springing up . . . . remove the hex headed screw that holds the side stand. Notice that the hex opening is unusually deep. File or grind enough of the screw head off so that the curved plate that pivots and the springs connect to just clears the head of the screw when you put the side stand down, fixed. Don't worry, there will still be enough depth in the hex opening to be able to tighten or loosen the screw in the future. du907 |
