It is currently Mon Apr 27, 2026 3:43 am
[ 11 posts ] |
| Author |
johnm
Post subject: throttle bodys Posted: Tue Oct 02, 2012 5:44 pm |
Joined: Mon Aug 03, 2009 2:04 pm Posts: 22 Location: USA
does anyone out there know where i can get a set of throttle body assembleys for my 1991 907 the shaft bushings are leaking air and i cant find anyone that can rebush them.
| Top |
Derek
Post subject: Re: throttle bodys Posted: Tue Oct 02, 2012 6:20 pm |
| paso grand pooh-bah |
Just wondering if the ST2 throttle bodies will fit? The throttle body from one of the injection SS models could be better as they have the pressure regulator mounted on them.The air bleed screw arrangement is different and it uses a different TPS which may need changing the connector if you can't swap the TPS over. Neither does it use the 8-pin round connector but that could be easily added. It would certainly be worth a look.
| Top |
Crumpati
Post subject: Re: throttle bodys Posted: Tue Oct 02, 2012 6:42 pm |
Joined: Mon Nov 28, 2011 8:50 am Posts: 30 Location: idsvold QLD Australia
Gowanlochs ad them about 6 months ago on eBay for about $300 AUD brand new.
| Top |
nickta
Post subject: Re: throttle bodys Posted: Wed Oct 03, 2012 12:01 am |
Joined: Tue Jul 24, 2012 8:54 am Posts: 287 Location: Cairns, Queensland, Australia
I picked up the complete set from Italspares in Aust about a month ago. They may still have a set or 2? I have the phone number here somewhere....
| Top |
ducbertus
Post subject: Re: throttle bodys Posted: Wed Oct 03, 2012 8:43 pm |
Joined: Sun Jan 07, 2007 12:00 am Posts: 531 Location: holland
Hi John,
are there realy metal bushings in the throttle body? I thoughed it's all plastic. when there are metal bushes they can ber rebushed. just machine them out on a mill. insert some new bronze bushings and ream them in line with a adjustable reamer. or a fixed one. reamers are available in several sizes in steps of 0.01 mm. I use a set of these for reaming valve guides.
Bertus
| Top |
johnm
Post subject: Re: throttle bodys Posted: Fri Oct 05, 2012 2:00 pm |
| Top |
20YearOwner
Post subject: Re: throttle bodys Posted: Fri Oct 05, 2012 3:52 pm |
Joined: Wed Aug 01, 2007 12:00 am Posts: 40 Location: Bristol, Connecticut USA
I have purchase hard to find Weber parts from a seller on ebay using the name "alfa1750" if you are an ebay member you could try to contact him, if not he mostly sells Weber carburetor rebuild kits. Do an ebay search for WEBER CARBS REBUILD KIT you should be able to find him. Use the "asked a question" box and give him a number he will email you with a price if he has the part.
| Top |
johnm
Post subject: Re: throttle bodys Posted: Fri Oct 05, 2012 10:18 pm |
| Top |
nickta
Post subject: Re: throttle bodys Posted: Sat Oct 06, 2012 12:09 am |
| Top |
johnm
Post subject: Re: throttle bodys Posted: Tue Oct 23, 2012 6:54 pm |
thanks to every one for the responses. nikta thanks i just got my new throttles from italspares, fantastic thanks again
john
| Top |
nickta
Post subject: Re: throttle bodys Posted: Fri Oct 26, 2012 9:16 am |
Hi John.
No worries about the phone number. Glad I could help.
I spoke to Jim yesterday and he said Italspares will be going online with their parts in the next month or so. Keep an eye out if they do.
Cheers.
Nick.
| Top |
[ 11 posts ] |
Users browsing this forum: No registered users and 12 guests |
