| is a startmotor of a S2 the same as one of the 907? http://ducatipaso.org/forum/viewtopic.php?f=3&t=4390 |
| Author: | ducbertus [ Sun Oct 24, 2010 6:24 pm ] |
| Post subject: | is a startmotor of a S2 the same as one of the 907? |
I have a startmotor of a ST2 laying around and want to check it, do the mod of earthing the - brush by a decent cable. just need to be sure that they are the same. so I can swap the starter motors in one action. Bertus |
| Author: | Finnpaso [ Mon Oct 25, 2010 3:49 pm ] |
| Post subject: | Re: is a startmotor of a S2 the same as one of the 907? |
I think, that if mechanical measurements are same, then You can use it. There cant be big difference with needeed current, so that electrical part you can forget. I havent look mine closer, but i quess, they are exact samekind, maybe from another manuafacturer, but that is not problem at all....
| Author: | ducbertus [ Mon Oct 25, 2010 9:11 pm ] |
Hi Annti, I knew you would post a reply. To be honest, I saw an article about startmotors where the writer changed the standard starter, which contains 2 brushes into 4 brushes. this doubles the torq of the starter and has a dramatic improvement on the starting of the big twins. That's what I aiming for. regards, Bertus |
| Author: | Tamburinifan [ Mon Oct 25, 2010 11:36 pm ] |
| Author: | ducbertus [ Tue Oct 26, 2010 4:30 pm ] |
Hi tamburinifan, it seems that there is a possibility to use a brush plate with already 4 brushes. not every 4-brush plate will fit. some brush plates have the spring to far out, causing short cicuit. so far I'vent any links to some articles about this subject sofar. Bertus |
| Author: | Tamburinifan [ Thu Oct 28, 2010 12:21 am ] |
Friend of mine tried to adapt similar 4 brushes to st engine, no luck. I bought one, too. Sould give more ooomphh f starter but not so easy to do even if that was almost the same. But I´m listening....
| Author: | 907pasonut [ Fri Nov 12, 2010 2:12 pm ] |
