Any suggestions? http://ducatipaso.org/forum/viewtopic.php?f=3&t=4487 |
Author: | Tamburinifan [ Thu Dec 09, 2010 10:32 pm ] |
Post subject: | Any suggestions? |
My top mount, the "ears", for my frame mount of rear shock is a little loose, around 0.35 mm. If you lift under the wheel to check f freeplay, (as Swedish MOT test does....), it feels like 2 mm. Any idea how to fix this? Weldable at all? |
Author: | 907pasonut [ Fri Dec 10, 2010 12:24 pm ] |
Post subject: | Re: Any suggestions? |
Gert, is it broken (what would you weld)...or does the suspension linkage have worn parts (bush/bearing) is the 2 mm play measured at the shock or at the rear wheel...2mm is not much if at the rear wheel |
Author: | Tamburinifan [ Fri Dec 10, 2010 1:32 pm ] |
The ears on frame where the top bolt is mounted are worn. Doesn`t bother me or compromise driving, main problemo actually MOT inspection. + it would be nice to fix it, if doable. |
Author: | angelix [ Fri Dec 10, 2010 2:02 pm ] |
Author: | persempre907 [ Fri Dec 10, 2010 6:07 pm ] |
I would say too a 2 mm. play is not a problem. Are you sure that when you'll do the MOT inspection will there be some problem? Ciao ![]() ![]() ![]() ![]() ![]() |
Author: | ducapaso [ Sat Dec 11, 2010 12:56 pm ] |
The "extreme solution" is to drill one of the two ears and build a special bolt with different size related to the two ears. Anyhow, a .35 mm freeplay should not be your matter, expecially if the bolt is correctly tighten. Have a nice job and... |
Author: | Tamburinifan [ Sun Dec 12, 2010 12:39 am ] |
OK, thx. Think I`ll skip the job. |
