ducatipaso.org • View topic - Coolant bottle cap
It is currently Mon Apr 27, 2026 12:03 pm
 Post subject: Coolant bottle cap
PostPosted: Wed Dec 22, 2010 9:07 am
Can anyone comment if i have it write or wrong on how the expansion bottle works.
There is a black rubber seal which fits over a white round disc mounted on a spring arrangement in the black cap which then screws onto the expansion bottle. When the cap is fitted the black rubber seal is located in the neck of the bottle, sealing off the overflow pipe.
When the pressure builds up the rubber seal is forced up compressing the spring which then allows the excess pressure to flow out the overflow pipe.
Would this also mean that the coolant is in a pressorized system?
 Post subject: Re: Coolant bottle cap
PostPosted: Wed Dec 22, 2010 9:18 am
spot on davo, the whole plastic tank is pressurized thats why they sometime split,
unless you do the honda CBR600 conversion :thumbup:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Wed Dec 22, 2010 10:25 am
Davo,
Where are you located"?
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
PostPosted: Thu Dec 23, 2010 10:25 am
Hi Jaffa, I`m in Geelong
