It is currently Mon Sep 29, 2025 9:37 am
 Post subject: fuel-tank/Closed!!
PostPosted: Sun Feb 20, 2011 10:12 pm
Does anyone know if the inside of the fuel-tank of a 750/906 Paso is the same as the one used on a 907IE, this because of the use of injection instead of carbs........
 Post subject: Re: fuel-tank
PostPosted: Mon Feb 21, 2011 12:32 am
The 907 Tank has inside the Holder for the Pump + Filter.
Part Number is 58610051BA (Red) or 58610051BB (Black)
The Paso 750 is 037083253
And it looks that the the Fuel exit is on different positions , and the 907 has 2 (outgoing + Return)
I say they are much different
RĂ¼diger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Mon Feb 21, 2011 9:18 am
As mentioned the internals are different as the P750/906 tank doesn`t have any.
It still may be possible to use one on a 907ie if you use an external fuel pump and fuel filter like on the P750/906. The tank has a return line so this wouldn`t be an issue. Fuel lines may need a different routing and you would need to find a place to mount pump and filter.
I don`t know if anyone has done this yet. I`d try to find a 907ie tank and if you can`t or they are too expensive I`d consider a P750/906 tank and the required modifications.
The bottom side of the tank, meaning the area of the airbox should be identical.
PostPosted: Mon Feb 21, 2011 9:52 am
it all depends where you live, here in Aus external uninsulated fuel lines are subject to hot temperatures and fuel vaporization can cause havoc during hot days at low speed, in this case its better to leave most FI parts inside tank submerged in cooler petrol :dunno:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
