ducatipaso.org :: View topic - Fuel Pump
ducatipaso.org
http://ducatipaso.org/forum/
Fuel Pump
http://ducatipaso.org/forum/viewtopic.php?f=3&t=460
Page 1 of 3
Author:  ynot [ Tue Jun 14, 2005 11:27 am ]
Post subject:  Fuel Pump
Hi!
My fuelpump (907-1991) Marelli PI-022 was stucking- when connecting power nothing happend (even no short circuit). After some "helps" with air pressure & bumps (i got it out of the tank) it moved again- sometimes doing some strange noises! I ordered a new one- but unfortenuatelly it wasn´t the original Marelli but a Wabco pump with a different outer diameter :neener: - but with the right box (Marelli PI-022). Had everyone of you have probs with the pump?
Does anyone know how to mount the Wabco pump-? the original fuelfilter does not fit to the Wabco pump :screwy:
Author:  ynot [ Mon Jan 03, 2011 9:41 am ]
Post subject:  Re: Fuel Pump and tank
Hello!
I reply to myself, caus the problem was getting virulent!.
Now- 5 years after that trouble disappeared by itself (gosh- Weber is an god), the (same) pump still works, but I broke the gland for the tube, so I need to replace it by a (cheap) original Weber PI-022.
Has anyone an idea if this part is available somewhere in Europe? Or has anyone of you this part "on stock"?
Unfortunately the tank is rusted and already has several holes, after I removed the varnish from certain spots, where only the color and the rust under prevented the petrol to run out...
What is the best method to repair such a heavily rusted piece of shit? And who will do such a work??
Best would be a "new" tank but...
Attaching some pics soon.
regards
Gernot from Vienna
Author:  907pasonut [ Mon Jan 03, 2011 10:36 am ]
hi Gernot, gees you replied to your own post 5yrs later...
cant help you with the fuel pump, but I had similar problem with tank leaking (very small leak) and used the tank repair kit which was recomended to me, that was my first post on this forum July/2010 with the heading "907ie petrol tank with very small petrol seepage" read that.
I strongly recomend this product and if you follow instructions it will bring your tank like new again :thumbup:
Author:  higgy [ Mon Jan 03, 2011 11:25 am ]
for the Euromarkets you can get it here
I am sure there are others outlets
Author:  ducapaso [ Mon Jan 03, 2011 2:12 pm ]
In Feb, 18th to 20th there will be a motorcycle used parts fair in milano, close to the Malpensa airport. have a look here:
I think you'll have good chances to find what you need and someone from germany able to translate your words to the sellers :)
Author:  persempre907 [ Wed Jan 05, 2011 6:21 pm ]
Really, there is some new tank around.
I guess Ducati has cleared its warehouse away.
http://cgi.ebay.it/SERBATOIO-DUCATI-PAS ... 3f062f631e
Author:  ynot [ Thu Jan 13, 2011 9:50 am ]
Finally I bought the tank (thanks for the Info!), I wonder if there aren´t to many scratches present.
But still I cannot find a Weber PI-022 fuelpump...
Valbro pumps definitely do not fit.
Does anyone have an idea? (for smaller money...).
Another question occurs as I stripped down the Cylinder heads (and the rest):
I always had trouble with small oil leaks coming from the Head (or cylinder) where the exhaust is located. I thought it comes from the copper stuffs (?) which are pressed into the head/ cylinder, but my mechanic says this is only to seal up the water-coolant.
I already changed the rubber rings twice, but after some time still it leaks a little bit. :suicide:
Does it come only from the rubber rings, or does it come from the (smaller) copper "thingis"
I will send some photos soon..
Gernot
Author:  Tamburinifan [ Thu Jan 13, 2011 9:53 am ]
Do a search on BMW pump here.
Author:  900streetfighter [ Thu Jan 13, 2011 6:12 pm ]
http://cgi.ebay.co.uk/Ducati-750-907-Pa ... 4cf46ba006
Theres a scruffy tank with good pump here going cheapish. If it doesn't sell he may sell the pump seperately.
Author:  ynot [ Wed Jan 19, 2011 8:57 am ]
Thanks for your help so far.
I made some pictures just to show you the present condition of the bike.
Today I got the overhoulded heads, the mec. meant that all the copper "studs" on the head are only for the collant- not for sealingthe oilroutes- can you confirm (I still wonder where the oil leakage next to the exhausts comes from, caus the sealing rings where new, and fastened with silicon..)?
What happened so far:
-new seat cover (selfmade- seciond time, got stiffness in my fingercups!)
-new petrol pipes
-cleaning of all plugs with contact cleaner
-new chain and sprockets
- repair of collant tank (second tank already, first try)
- many many small things to repair and adopt
and cleaning, cleaning, cleaning
still to come:
"new" tank with "kreem weiss" coating (I will post a picture of the perforated tank soon)
"new" fuelpump
new filter
Bodywork to be revarnished completely (decals already here)- RED rules!
Author:  Duc906 [ Thu Jan 20, 2011 12:43 am ]
Author:  ynot [ Thu Jan 20, 2011 11:28 am ]
Hello!
I was quite sure that it was oil, it even had a light colour (fresh oil).
The mecanic ment, that it only can come from the sealing o- rings.
The pictures are from the already overhoulded heads.
Before there were no similar deposits as on your head (cylinder area).
Author:  higgy [ Thu Jan 20, 2011 11:44 am ]
The Weber fuel pump for DUCATI ( Motorcycles) 907ie (Weber PI-022) 139.34(GBP) 164.60(eur) 222.30(USD) 221.55(AUD) 288.40(NZD)
Author:  Tamburinifan [ Thu Jan 20, 2011 11:55 am ]
Author:  ynot [ Thu Jan 20, 2011 2:04 pm ]
In fact nothing than cleaning and valve adjusting...
As the copper studs are not responsible for the oil leaking I think that the sealing rings are the bad guys- I just wonder if and why...
I´m afraid the merlin pump is the Walbro thing which doesn´t fit 1:1 because of smaller diameter.
So filter and rubberhose does not fit...
I have a new one at home, anyone interested?
Page 1 of 3 All times are UTC
http://www.phpbb.com/
