Brake fluid http://ducatipaso.org/forum/viewtopic.php?f=3&t=4631 |
Author: | Leonardo [ Wed Mar 02, 2011 3:09 pm ] |
Post subject: | Brake fluid |
I need to change it, pls what is the equivalent of Agip F1 brake fluid super HD DOT that the owners manual says ??? The DOT 4 or the DOT 5.1 ???? Thanks |
Author: | paso750 [ Wed Mar 02, 2011 3:54 pm ] |
Post subject: | Re: Brake fluid |
Leonardo, use any DOT4 brake fluid. DOT5.1 would be ok, too but not DOT5 ! DOT5 is silicon based and cannot be mixed with the other types. DOT5.1 has a higher boiling point but also much shorter changing intervals so unless you race the bike stay with DOT4. What manufacturer it is from is not important. G. |
Author: | Leonardo [ Wed Mar 02, 2011 4:25 pm ] |
Thanks paso750 !!! Do you know how many i need to buy for change rear an front brake and clutch ?? 250 ml or 500 ml bottle ??? |
Author: | paso750 [ Wed Mar 02, 2011 5:54 pm ] |
250ml is probably sufficiant but I guess it depends on if you want to totally flush the system. Brake fluid is not expensive. I guess I`d take two 250ml bottles ![]() G. |
Author: | persempre907 [ Sat Mar 12, 2011 3:03 pm ] |
Doing the work, why do not replace the clutch fluid, too? Ciao ![]() ![]() ![]() ![]() ![]() |
Author: | ducbertus [ Thu Mar 17, 2011 9:01 pm ] |
be aware that braking fluid is hygroscopic. once the seal on the can is opened the proces of saturation is starting. So, buy little cans. I don't use fluid from a bottle older than 2 years. Bertus |
