My brake light does not work, HELP!!!! http://ducatipaso.org/forum/viewtopic.php?f=3&t=4690 |
Author: | Antzo [ Thu Mar 24, 2011 8:27 pm ] |
Post subject: | My brake light does not work, HELP!!!! |
Both front and rear light brake valve does not work. When I bridge the wires it lights up so it is definitely the light valves. I was told at my local Ducati dealer that they are discontinued. What can I do ??? ![]() ![]() ![]() |
Author: | higgy [ Thu Mar 24, 2011 9:21 pm ] |
Post subject: | Re: My brake light does not work, HELP!!!! |
For the rear, any hydralic light switch in a M10x1.0 thread should work try your local auto supply. I seem to remember some one found the same switch on a BMW motorcycle. I'm sure Guzzi has one as well. For the front it is availible from a few sources here in the states, Maybe some one else can tell you where to find it in your neck of the world. |
Author: | ducbertus [ Thu Mar 24, 2011 10:13 pm ] |
you may try www.stein-dinse.com in Germany. they hold large stock of Ducati and Guzzi parts. in the front lines there is this dividing block underneath the lower yoke, when I'm right there is a thread unused. when so, it has M10 x 1 as higgy stated. I've also seen microswitches on the mastercilinder at the handle bar. Bertus |
Author: | JoKing [ Fri Mar 25, 2011 7:20 am ] |
Both switches i`ve got here. Don`t need them, because i have them twice. 40€ for both, plus shipment. |
Author: | Antzo [ Fri Mar 25, 2011 10:20 am ] |
Author: | ducbertus [ Fri Mar 25, 2011 9:06 pm ] |
or try www.conrad.de and look for microswitches. there a vast array of swichtes on their site. I use them also for my car. Bertus |
Author: | Antzo [ Fri Mar 25, 2011 10:49 pm ] |
You have enlightened me enough thanks, I will do a research in the local market and then if nothing comes up I will buy from abroad. |
