Fuel line connections http://ducatipaso.org/forum/viewtopic.php?f=3&t=4923 |
Author: | viciouscycle [ Fri Jul 08, 2011 6:46 am ] |
Post subject: | Fuel line connections |
Today's issue: I failed to properly mark the fuel line connections coming out of the bottom of the tank. There are four spiggots. From the front to the rear, the first is the out line, the second the return line. One of the two rear spiggots is for the overflow...but the other? Vent perhaps. Of these two, which is which? I think the rearmost is for the overflow. Any suggestions? Many thanks, |
Author: | paso750 [ Fri Jul 08, 2011 8:12 am ] |
Post subject: | Re: Fuel line connections |
Randy, check p.28/29 of the user manual (you find it in the downloads if you don`t have it). G. |
Author: | viciouscycle [ Sun Jul 10, 2011 11:25 am ] |
Many thanks G. I knew I saw the diagram somewhere. |
