| Which bearing type for swingarm? http://ducatipaso.org/forum/viewtopic.php?f=3&t=5034 |
| Author: | JoKing [ Sun Aug 28, 2011 8:37 am ] |
| Post subject: | Which bearing type for swingarm? |
Hi guys, i need the type/naming of all swingarm bearings & shaft seals. I do not want to buy them at ducati. They`d cost more than the swingarm itself. Anyone knows? Here the original part #s: 764000001 041202295 751632054 075549265 764000002 Cheers, Johannes |
| Author: | JWilliam [ Tue Sep 06, 2011 8:35 pm ] |
| Post subject: | Re: Which bearing type for swingarm? |
I have only had to replace the bearing and seals for the shock linkage - 5 bearings total. The gearbox/frame pivot bearings were OK so I don't know the exact size for them (the right side is a double sealed type). If this is familiar then I can quote the linkage sizes. |
| Author: | paso750 [ Tue Sep 06, 2011 8:54 pm ] |
you find them all listed in the FAQs http://ducatipaso.org/forum/viewtopic.p ... c&start=15 all swingarm bearings are the same on P750/906 & 907ie. G. |
| Author: | pasolloyd [ Thu Sep 15, 2011 11:55 pm ] |
The numbers I retrieved from my swing arm are as follows: 075549265: 26mm x 20mm x 4mm seal 764000002: 260D 201D 18L bearing Sorry I don't have the others... Lloyd |
| Author: | pasolloyd [ Fri Sep 16, 2011 12:25 am ] |
Oops! The others were on the previous page! I can see also some were not part numbers but sizes for the bearings. Let's try again: 764000001: 32mm OD x 25mm ID x 18mm L needle bearing 041202295: 32mm x 25mm x 4mm seal 751632054: #630004 2RS1C3 075549265: 26mm x 20mm x 4mm seal 764000002: 26mm OD x 20mm ID x 18mm L needle bearing Again, these were taken from my swingarm components |
| Author: | JWilliam [ Sun Sep 18, 2011 4:02 pm ] |
Aftermarket bearing sizes then : Mfr SKF Bearings Swingarm linkage bearings are 4 x HK2020 Needle bearing,1 x HK2030 Needle bearing and 6 x G20x26x4 Seal Sprocket Carrier (always a good idea) 2 x 6005 2RS1 |
