JE psitons quality http://ducatipaso.org/forum/viewtopic.php?f=3&t=5124 |
Author: | ducbertus [ Mon Oct 17, 2011 9:46 pm ] |
Post subject: | JE psitons quality |
has anyone experience with JE pistons about weight, durability, etc. I saw a set offered, but don't know them. Any input is welcome. Bertus |
Author: | jcslocum [ Mon Oct 17, 2011 11:28 pm ] |
Post subject: | Re: JE psitons quality |
They are very good pistons. Lots of racers and others use them. I think they are all forged. |
Author: | Tamburinifan [ Tue Oct 18, 2011 12:51 am ] |
A little lighter than standard, like 25 gram each or so. Have no problems w them, have them in both my bikes. |
Author: | ducbertus [ Tue Oct 18, 2011 7:51 am ] |
Jon and Gert, thank you for your comments. ![]() Gert, do you know by chance how heavy the original pistons are? something about 500 gram? Bertus |
Author: | Tamburinifan [ Tue Oct 18, 2011 2:09 pm ] |
IIRC, JE 435g & OEM 460. If buying a used set and want fresh rings, do buy from US, veeery much cheaper! http://www.ca-cycleworks.com/ has them f e. |
Author: | Shelboss [ Thu Oct 27, 2011 2:14 am ] |
A word of warning about used pistons, Ducati's have a tight tolerance on the piston to wall clearance. They classified pistons as A or B fit. I bought a used set only to find they had too much clearance. They also wear in the ring grooves. I looked into stock bore J&E pistons, but no gaurantee that the Nikasil plating would not have to be redone for fit. I ended up buying J&E ST-2 pistons, sending the cylinders and pistons to Millenium for a bore and Nikasel plating, and shimming the 11:1 pistons to yield 10:25 compression. I use a FBF chip and 89 octane gas, the motor runs strong and gives me a consistent 50 mpg. I highly recommend J&E and CA cycleworks ![]() |
