| Turn signal Lens for front? http://ducatipaso.org/forum/viewtopic.php?f=3&t=5192 |
Page 1 of 2 |
| Author: | du907 [ Wed Dec 21, 2011 9:25 pm ] |
| Post subject: | Turn signal Lens for front? |
Anyone know where I can get turn signal lens for the front of a 907? I've tried the local dealers and the internet but I'm not coming up with any leads. Thanks, du907 |
| Author: | higgy [ Wed Dec 21, 2011 9:59 pm ] |
| Post subject: | Re: Turn signal Lens for front? |
Been looking myself Last pair I got was from Ducati of Omaha about a year ago. Let know if you run across some............. |
| Author: | Crumpati [ Thu Dec 22, 2011 3:39 am ] |
This guy has mirrors, might have lenses as well!! |
| Author: | du907 [ Thu Dec 22, 2011 3:48 am ] |
Tried Omaha and they said the part is no longer available. du907 |
| Author: | higgy [ Thu Dec 22, 2011 5:24 am ] |
| Author: | higgy [ Thu Dec 22, 2011 5:25 am ] |
Maybe Jonboy has a source ? |
| Author: | JoKing [ Thu Dec 22, 2011 6:59 am ] |
Here you are: http://www.ebay.de/itm/DUCATI-Blinker-i ... 5891383d60 |
| Author: | paso750 [ Thu Dec 22, 2011 9:25 am ] |
you could also try http://www.mgcycle.com/ They are a Guzzi shop but a distributor of Stein Dinse a german Duc/Guzzi parts dealer. Stein Dinse has the lenses so maybe mgcycles can get them, too. G. |
| Author: | Derek [ Thu Dec 22, 2011 10:07 am ] |
Thanks for posting the eBay link. The LH lens on mine has been broken and glued together so it is probably only a matter of time before it disintegrates. A new pair will look so much better.
| Author: | du907 [ Thu Dec 22, 2011 7:57 pm ] |
Derek, If you get them before me let me know. I'm fixing my 907 after a wreck this past May and I will need at least one lens and the reflector with wiring. If I get them before you and will gladly let you have the one left over for whatever it cost me. du907 |
| Author: | Derek [ Thu Dec 22, 2011 8:54 pm ] |
None of my lens are too good so I've ordered a pair anyway. |
| Author: | higgy [ Fri Dec 23, 2011 12:41 am ] |
Stein Dinse has none to sell either |
| Author: | paso750 [ Fri Dec 23, 2011 8:41 am ] |
which seems strange as their (german) webshop shows them marked green (in stock) http://www.sd-tec.de/catalog/quick_sear ... 1d6def5030 Mdina in the UK seems to have them (but only the lenses not the reflector + lens kit) http://www.mdinaitalia.co.uk/cgi-bin/co ... egory=BTPA right lens ebay Germany http://www.ebay.de/itm/DUCATI-Blinkergl ... 2568f96154 |
| Author: | higgy [ Fri Dec 23, 2011 1:06 pm ] |
missed the kit at Stein it is lenses they are out of
| Author: | firehawk75 [ Tue Dec 27, 2011 10:34 pm ] |
i just ordered the right hand one from ducati in omaha. had to find part number and then they can order it |
