ducatipaso.org • View topic - Turn signal Lens for front?
It is currently Tue May 05, 2026 3:08 am
 Post subject: Turn signal Lens for front?
PostPosted: Wed Dec 21, 2011 9:25 pm
Anyone know where I can get turn signal lens for the front of a 907?
I've tried the local dealers and the internet but I'm not coming up with any leads.
Thanks,
du907
 Post subject: Re: Turn signal Lens for front?
PostPosted: Wed Dec 21, 2011 9:59 pm
Been looking myself
Last pair I got was from Ducati of Omaha about a year ago.
Let know if you run across some.............
PostPosted: Thu Dec 22, 2011 3:39 am
This guy has mirrors, might have lenses as well!!
PostPosted: Thu Dec 22, 2011 3:48 am
Tried Omaha and they said the part is no longer available.
du907
PostPosted: Thu Dec 22, 2011 5:24 am
PostPosted: Thu Dec 22, 2011 5:25 am
Maybe Jonboy has a source ?
PostPosted: Thu Dec 22, 2011 6:59 am
Here you are:
http://www.ebay.de/itm/DUCATI-Blinker-i ... 5891383d60
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
PostPosted: Thu Dec 22, 2011 9:25 am
you could also try
http://www.mgcycle.com/
They are a Guzzi shop but a distributor of Stein Dinse a german Duc/Guzzi parts dealer. Stein Dinse has the lenses so maybe mgcycles can get them, too.
PostPosted: Thu Dec 22, 2011 10:07 am
Thanks for posting the eBay link. :thumbup:
The LH lens on mine has been broken and glued together so it is probably only a matter of time before it disintegrates. A new pair will look so much better. :)
PostPosted: Thu Dec 22, 2011 7:57 pm
Derek,
If you get them before me let me know. I'm fixing my 907 after a wreck this past May and I will need at least one lens and the reflector with wiring. If I get them before you and will gladly let you have the one left over for whatever it cost me.
du907
PostPosted: Thu Dec 22, 2011 8:54 pm
None of my lens are too good so I've ordered a pair anyway.
PostPosted: Fri Dec 23, 2011 12:41 am
Stein Dinse has none to sell either
PostPosted: Fri Dec 23, 2011 8:41 am
which seems strange as their (german) webshop shows them marked green (in stock)
http://www.sd-tec.de/catalog/quick_sear ... 1d6def5030
Mdina in the UK seems to have them (but only the lenses not the reflector + lens kit)
http://www.mdinaitalia.co.uk/cgi-bin/co ... egory=BTPA
right lens ebay Germany
http://www.ebay.de/itm/DUCATI-Blinkergl ... 2568f96154
PostPosted: Fri Dec 23, 2011 1:06 pm
missed the kit at Stein
it is lenses they are out of :fart:
PostPosted: Tue Dec 27, 2011 10:34 pm
i just ordered the right hand one from ducati in omaha. had to find part number and then they can order it
