It is currently Fri Nov 14, 2025 9:28 am
Page 1 of 1
[ 7 posts ] |
| Author |
Message |
torpedo51
Post subject: servicing a marzocchi rear shock Posted: Sun Jan 08, 2012 7:15 am |
Joined: Mon Jun 06, 2011 6:31 am Posts: 17 Location: Los Angeles,CA & Reno,NV
When I fully compress the rear shock, the rebound appears to be undampened for the first 80% of the return travel, then is dampened for the last 20% of travel.
Is it low on oil/N2? Service or replace it?
_________________ Making a mechanic out of me: 1988 Paso 750 | 1991 907ie
| Top |
Post subject: Re: servicing a marzocchi rear shock Posted: Sun Jan 08, 2012 10:48 am |
| paso grand pooh-bah |
Servicing is for sure cheaper. There`re used ones for sale once in a while but one never knows their real condition. If you decide to service yours take a close look at the damper rod. If the chrome is chipped or damaged that maybe the reason why an oil seal leaked. Over the time you`ll also notice that the swingarm linkage is oily. I had that on my first shock so I took it to the main Marzocchi importer. They told me I`d need to replace it as it was impossible to find a spare damper rod. According to them polishing or rechroming was no durable solution. So it would be important to find out why the shock doesn`t work properly anymore, if due to a damage or just as a matter of age.
| Top |
torpedo51
Post subject: Re: servicing a marzocchi rear shock Posted: Mon Jan 09, 2012 6:31 am |
Ok, I do understand the need for an undamaged shaft.
What affect does the N2 charge perform? Could this cure my rebound problem?
Is it possible to perform a "leakdown" test on the unit to verify the seals/o-rings are bad?
Can I add oil myself somewhere?
Do we have a manual for the specific unit used on our bikes?
I'm asking because whenever I go to a shop around here without some idea of what to expect, they flat out screw me.
| Top |
angelix
Post subject: Re: servicing a marzocchi rear shock Posted: Mon Jan 09, 2012 9:21 am |
Joined: Thu Nov 29, 2007 2:38 am Posts: 338 Location: UK
| Top |
torpedo51
Post subject: Re: servicing a marzocchi rear shock Posted: Wed Feb 01, 2012 7:12 pm |
Help!
The shop that is rebuilding the shock can't find replacement seals or seal head.
Does anyone know where to source these parts or have a cross referenced part from another vendor? Its a 14mm ID with a 40mm OD. My seal head has the hex head to accept a wrench rather than two holes for a pin driver.
Thanks!
| Top |
Page 1 of 1
[ 7 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
