It is currently Thu Apr 30, 2026 9:11 pm
[ 3 posts ] |
| Author |
JoKing
Post subject: Disassemble a Marving exhaust can... Posted: Fri Jan 20, 2012 7:17 pm |
Joined: Mon Jun 20, 2005 12:00 am Posts: 362 Location: Northern Germany / Kiel
Hi, i want to change the "shell" of my Marving exhausts. I already drilled out the rivets, but i can`t get it apart. Somebody knoes how it works? Is it glued somehow?
_________________ 92` Ducati 907 i.e. - ST3-Conversion --> Burned down with my barn 78` Ducati 900 SS - Bevel --> Sved her by risking my life 90` Cagiva Freccia C12R - Paso`s smaller sister --> Burned down with my barn 86` Ducati 750 Paso 96` Cagiva 750 AC Elefant
| Top |
ducinthebay
Post subject: Re: Disassemble a Marving exhaust can... Posted: Sat Jan 21, 2012 3:10 am |
| paso grand pooh-bah |
Most of the exhausts are pressed together with surprisingly tight tolerances. Don't want them to rattle. General rule is to remove the silencer from the bike, and use a good solid broomstick inserted from the inlet side to push it out. May take a bit of banging the end of the stick on the ground and forcing the innards out the back end. Of course a liberal dosing of Liquid Wrench will help.
If it isn't the tight tolerances fighting you, its the carbon deposits.
I battled with a slide hammer for hours getting nowhere, then used the broomstick method and freed them right up. I was taking apart a BUB exhaust.
| Top |
Post subject: Re: Disassemble a Marving exhaust can... Posted: Sat Jan 21, 2012 9:17 am |
a few exhausts also use a sealing band that can still stick when the rivets are removed.
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 13 guests |
