| Disassemble a Marving exhaust can... http://ducatipaso.org/forum/viewtopic.php?f=3&t=5235 |
| Author: | JoKing [ Fri Jan 20, 2012 7:17 pm ] |
| Post subject: | Disassemble a Marving exhaust can... |
Hi, i want to change the "shell" of my Marving exhausts. I already drilled out the rivets, but i can`t get it apart. Somebody knoes how it works? Is it glued somehow? |
| Author: | ducinthebay [ Sat Jan 21, 2012 3:10 am ] |
| Post subject: | Re: Disassemble a Marving exhaust can... |
Most of the exhausts are pressed together with surprisingly tight tolerances. Don't want them to rattle. General rule is to remove the silencer from the bike, and use a good solid broomstick inserted from the inlet side to push it out. May take a bit of banging the end of the stick on the ground and forcing the innards out the back end. Of course a liberal dosing of Liquid Wrench will help. If it isn't the tight tolerances fighting you, its the carbon deposits. I battled with a slide hammer for hours getting nowhere, then used the broomstick method and freed them right up. I was taking apart a BUB exhaust. Cheers, |
| Author: | paso750 [ Sat Jan 21, 2012 9:17 am ] |
a few exhausts also use a sealing band that can still stick when the rivets are removed. |
