| ST 2 CAMS??? http://ducatipaso.org/forum/viewtopic.php?f=3&t=5271 |
| Author: | oceanhunter [ Mon Feb 20, 2012 7:27 am ] |
| Post subject: | ST 2 CAMS??? |
Does anybody know if st2 cams fit in 907?if so any mods required,any gains to be had? Just pulled heads off to fit mbp collets ohlins shock fitted braided lines all round but broke cam belt idler pully bolt ,replacing belts and rollers and dial in cams wish me luck trip down west coast nz for best little airshow inthe world
| Author: | Derek [ Mon Feb 20, 2012 12:29 pm ] |
| Post subject: | Re: ST 2 CAMS??? |
They should fit straight in but you will need to completely re-shim all the clearances. |
| Author: | Bock900r [ Mon Feb 20, 2012 4:37 pm ] |
And how to connect the tachometer cable? Or do you have a electronic Instrument? |
| Author: | Derek [ Tue Feb 21, 2012 10:15 am ] |
| Author: | higgy [ Tue Feb 21, 2012 12:55 pm ] |
The hard part will be finding the cams
| Author: | Bock900r [ Tue Feb 21, 2012 3:21 pm ] |
| Author: | mh906evo [ Thu Feb 23, 2012 8:02 pm ] |
Hi, I just got a pair for my 907, I can say that they are a perfect fit. The problem is to get them for an acceptable price if you don't want to buy them new for about 700€ (prive in Germany) Good luck ! Rainer |
| Author: | JoKing [ Fri Mar 09, 2012 3:25 pm ] |
| Author: | ottovalvole [ Fri Mar 09, 2012 7:06 pm ] |
Hi Why fit ST2 cams? |
| Author: | higgy [ Fri Mar 09, 2012 7:59 pm ] |
more overlap in the timing = more power on the high end of the rpm band |
