ducatipaso.org • View topic - Flasher switch?
It is currently Fri Nov 14, 2025 6:35 am
 Post subject: Flasher switch?
PostPosted: Tue Mar 27, 2012 1:33 am
Hi guys
The flasher switch (for the directional lights) mysterious broke and i need to find a replacement.
I have ebay searches going, but no luck so far. Does a switch from any other model of Ducati fit?
Thanks in advance.
 Post subject: Re: Flasher switch?
PostPosted: Tue Mar 27, 2012 7:51 am
You mean the handlebar switch ? The whole assy is the same on all Paso, Sports, early Supersports and if I remember well also 851/888. Later models may look the same but have different type connectors.
If you`re good soldering it`s no problem to replace the connector of a newer handlebar switch assy with your old connector.
This one`s in the UK
http://www.ebay.com/itm/Ducati-Left-Han ... 1c25146d7d
PostPosted: Tue Mar 27, 2012 5:47 pm
I can confirm 851 & 888 have got the same left switch.
And it's so: depending by the model the connector can be different.
PostPosted: Wed Mar 28, 2012 9:49 am
The Supersports up until 1997 are also the same.
PostPosted: Sat May 05, 2012 2:39 am
thanks for the information - i wil expand my search!
