ducatipaso.org
http://ducatipaso.org/forum/
907 Fuel Cap leaking
http://ducatipaso.org/forum/viewtopic.php?f=3&t=5385
Author:  2vtwin [ Wed May 16, 2012 4:06 pm ]
Post subject:  907 Fuel Cap leaking
So the area around the fuel cap has started leaking, more of a weeping, after some investigation it would appear it is coming through at the bolts, rather than the outer part of the ring or the seal between the cap and the ring. I replaced the gasket under the outer ring with NOS gasket but not exactly sure it was the right part, the bolt pattern was the same, but the holes maybe a little larger and the rubber curls up slightly once the bolts are tightened. Anyone else had a similar problems? I'm thinking I should start with a gasket I know is the correct part number, anyone know of a source? Any other ideas? Thanks - Gene
Author:  900streetfighter [ Thu May 17, 2012 6:21 am ]
Post subject:  Re: 907 Fuel Cap leaking
Might be the breather pipe that fits to the cap. I had similar problem,that was the cure.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
