It is currently Thu May 07, 2026 10:28 pm
[ 2 posts ] |
| Author |
2vtwin
Post subject: 907 Fuel Cap leaking Posted: Wed May 16, 2012 4:06 pm |
Joined: Mon Jun 22, 2009 9:40 am Posts: 45 Location: USA
So the area around the fuel cap has started leaking, more of a weeping, after some investigation it would appear it is coming through at the bolts, rather than the outer part of the ring or the seal between the cap and the ring. I replaced the gasket under the outer ring with NOS gasket but not exactly sure it was the right part, the bolt pattern was the same, but the holes maybe a little larger and the rubber curls up slightly once the bolts are tightened. Anyone else had a similar problems? I'm thinking I should start with a gasket I know is the correct part number, anyone know of a source? Any other ideas? Thanks - Gene
_________________ "It's about the Journey, Not the destination" AMA Charter Life Member, Victory Motorcycle Club, Charter Member, Patriot Guard Rider 02' M900 01' Victory SC 04' Victory KP 09' HD XR1200 14' Ducati Diavel 16' Victory Cross Country Tour
| Top |
900streetfighter
Post subject: Re: 907 Fuel Cap leaking Posted: Thu May 17, 2012 6:21 am |
Joined: Wed Oct 27, 2010 5:52 pm Posts: 364 Location: Essex UK
Might be the breather pipe that fits to the cap. I had similar problem,that was the cure.
| Top |
[ 2 posts ] |
Users browsing this forum: No registered users and 18 guests |
