| going to start putting it together question http://ducatipaso.org/forum/viewtopic.php?f=3&t=5506 |
| Author: | bobst2 [ Sun Aug 05, 2012 3:14 pm ] |
| Post subject: | going to start putting it together question |
at my electric,s plate near the headlite there are two ground wires 1 goes to the regulator but the other i broken off just hanging there any ideas where it goes |
| Author: | Tamburinifan [ Wed Aug 08, 2012 12:41 pm ] |
| Post subject: | Re: going to start putting it together question |
Do you have 2 wires from alternator cover to regulator? |
| Author: | bobst2 [ Wed Aug 08, 2012 1:05 pm ] |
yes. two wire stator i think i figured it out the electric,s board is on rubber isolators so the second one must go two the frame |
| Author: | bobst2 [ Sun Aug 12, 2012 1:32 pm ] |
well fired it up with the 2 into 1 conti alloy system and it sounds great. had to do a little hammer mods to the front pipes to get propper clearence. started testing stuff found i had no chargeing system but was only a bad connection now that system is working now i am going on to the brakeing system going to need hoses and a proper flush also the micro switch is shot. hopefuly the last of the body panels & stuff arrive soon.i am starting to get anxious to take it for a ride |
