| poor running http://ducatipaso.org/forum/viewtopic.php?f=3&t=5741 |
| Author: | johnm [ Tue Jan 01, 2013 12:40 am ] |
| Post subject: | poor running |
hello everyone, i am having a running problem with my 907. its running too lean(at about 2% co) and it will not adjust. i checked the voltage on the 2 wires that come from ECU and there is 12.3v all the time and i dont think it should be that high. i also checked the voltage at the adjuster and it goes from 0 to 5 volts so its ok, if anyone knows what the voltage should be to the injectors that would be great. thanks and happy new years |
| Author: | Tamburinifan [ Tue Jan 01, 2013 1:57 am ] |
| Post subject: | Re: poor running |
Is the TPS set correctly? The CO adjuster on the ECU don't make any difference? Are the idle balance screws fully turned in? Fully in gives less air & richer at idle. |
| Author: | higgy [ Tue Jan 01, 2013 12:37 pm ] |
Info on proper tuning |
