| timing belt tensioner bearing availability ? http://ducatipaso.org/forum/viewtopic.php?f=3&t=5838 |
| Author: | Stingray230SX [ Tue Feb 12, 2013 11:36 pm ] |
| Post subject: | timing belt tensioner bearing availability ? |
i will be doing my 907's belts in the next month or so, hopefully before it gets real warm, finding the belts seems easy[anyone have a preference for bucci or the ca-cycleworks? or should i persue the gates Gates powergrip 5297-070x18mm ?, and i havent checked the tensioner bearings yet[bike stored off site from the house this year] hoping for a nice warm weekend to get it over here and start getting it ready for the belt change/oil change etc. anyway, back to the tensioner bearings, i thought i would replace them this time, as i didnt when i first purchased it and changed the belts, so does anyone know where i can get them? havent really searched yet, saw a set of old used ones on ebay, but i hope to find some newones. thanks doug |
| Author: | nickta [ Wed Feb 13, 2013 2:23 am ] |
| Post subject: | Re: timing belt tensioner bearing availability ? |
Hi Doug. I just purchased a set of SKF bearings for the 907. I found the SKF number on the Stein-Dense Web site. It was SKF 6201-2RSH. According to the crowd I got them off the 2RSH stands for 2 Rubber Seal, High speed. You need 4 to replace them all. The idler bearings are a bit harder to come by, but they were available from the Duc Shop I rang up. They aren't cheap though! Cheers. Nick. |
| Author: | Stingray230SX [ Wed Feb 13, 2013 3:49 am ] |
thanks, those tensioner bearings [skf #'s] are available at allied electronics only 5.xx a piece. i cant seem to find my parts book at the moment, does anyone have the p/n for the idler[wide roller] i found a ducati site to see if they have this p/n, but cant seem to find the number for the idler.[not a single ducati shop in my state [WV] so i am hoping to find them online. http://www.motospecialties.com/partorde ... ucatiOmaha thanks doug |
| Author: | nickta [ Wed Feb 13, 2013 5:06 am ] |
Hi Doug. Part No I have for the idler is 037029350. This may have been superseded? Cheers. Nick. |
| Author: | paso750 [ Wed Feb 13, 2013 10:44 am ] |
that number is still correct. Unluckily it seems like you can`t get those parts anywhere else than from Ducati and in the US they can cost from $80 to over 100 ea. In case you`re not in a hurry you can get them from Stein Dinse in Germany. According to their website they still have a few in stock http://www.stein-dinse.biz/Ducati/Engin ... S::19.html G. |
| Author: | Stingray230SX [ Wed Feb 13, 2013 2:00 pm ] |
thanks so much guys, i still havent been able to locate my ducati documents, and i know i downloaded backups and everything.... so, according to the online site at ducati of omaha that number is superceded by 45120211A and they are 53.99 each and at stein-dinse they are 50.10 US so thats close enough thanks again guys UPDATE 2-13-2013 **found my files so i wont bother u guys anymore** just glad i didnt lose them, now on a thumb drive as well as two different harddrives...... doug |
