| Brake pump 907 i.e. http://ducatipaso.org/forum/viewtopic.php?f=3&t=5872 |
| Author: | wiliboy [ Tue Mar 05, 2013 5:13 pm ] |
| Post subject: | Brake pump 907 i.e. |
Hi, i´m from czech republic and in this week i´m going to buy 907ie. Everything is in good original condition...almost. Only front brake pump isn´t. Is this difference a fault? Or..is it possible to buy an original pump? Thanks for all opinions. |
| Author: | paso750 [ Tue Mar 05, 2013 6:17 pm ] |
| Post subject: | Re: Brake pump 907 i.e. |
I`m not sure I understand if the brake pump is not ok or was replaced by another one. Basically you can use any brake pump no matter if it`s an original Brembo, a Brembo brake pump from a newer Ducati model, a Nissin from a japanese bike or any aftermarket. G. |
| Author: | wiliboy [ Wed Mar 06, 2013 10:03 am ] |
| Author: | paso750 [ Wed Mar 06, 2013 10:16 am ] |
A different brake pump will not influence the value of the bike. The 907ie is far away of being an investment with increasing value such as a bevel 750 Supersport. The brake pump was used on different bikes: http://www.stein-dinse.biz/Brembo/Hand- ... anguage=en |
| Author: | wiliboy [ Wed Mar 06, 2013 11:49 am ] |
| Author: | persempre907 [ Thu Mar 07, 2013 6:49 am ] |
If you are searching for a collectible bike which could rise in value in the future, then buy the F3 400. The 907 probably will not increase in value so how the F series. About the front brake master cylinder (or pump). The most important thing is that the bike brakes very well. Besides, you van think about the other things. So, if you want to have the bike fully stock, it will be enough you get and keep a stock pump. You will find it very easily because probably she is the most common pump on Ducati, monted until the Monster series, if I well remember. I have a 999's pump and some upgraded rotors and calipers, but also all the stock bits. This is the most important thing. Let us know about your purchase. Ciao |
| Author: | Ducolaf [ Mon Mar 11, 2013 10:01 pm ] |
Could you be looking for this type of brake pump on the 907? Used in the earlier 900 SS types, later replaced by a plastic reservoir. Must say the price is, to my opinion, quit high being 107 Euro. Use ebay search so you get an alert every time some items are placed on ebay, use words like "ducati, brake pump, front, paso, 907, ss, supersport" Sit back and wait for the right one to be posted with an acceptable price. Works for me. Found an other one: Please check on oem partnumbers, as I did not on these! |
| Author: | persempre907 [ Tue Mar 12, 2013 6:00 am ] |
For a such amount you can get a brand new one!!! http://www.ebay.de/itm/BREMBO-Bremszyli ... 2577a499f4 You have to search for Brembo PS 16. Good luck Ciao |
