| New Design Timing Belts. What do you Think? http://ducatipaso.org/forum/viewtopic.php?f=3&t=5986 |
| Author: | du907 [ Mon Apr 22, 2013 10:01 pm ] |
| Post subject: | New Design Timing Belts. What do you Think? |
I just got these new belts from Bevel Heaven made by an Italian company named Bucci. They are Kevlar and are for various Ducatis, including the 907ie. https://store.bevelheaven.com/engine-re ... down-menu/ When I got them, they have wedge shaped teeth. Our bikes usually have rounded teeth, 70 teeth per belt. I talked to the guys at Bevel Heaven and he said that Bucci has a patented design with these teeth that make them work on Ducatis that use the round tooth belts or the wedge shaped teeth, these belts have 70 teeth. I have enclosed a picture, take a look and see what you think. The old or original belt is on the outside, the new design belt is on the inside of the bend. See those 2 points at the end of the teeth. There is some other "textures" on the teeth that doesn't show but apparently this is their patented technology. |
| Author: | higgy [ Mon Apr 22, 2013 11:35 pm ] |
| Post subject: | Re: New Design Timing Belts. What do you Think? |
Bucci belts are some of the best and always have been |
| Author: | persempre907 [ Tue Apr 23, 2013 5:10 am ] |
| Author: | 900streetfighter [ Tue Apr 23, 2013 9:25 am ] |
They are not much cheaper than oe(price is each belt?). Do they still need changing every 2 years? |
| Author: | st2sam [ Tue Apr 23, 2013 11:33 am ] |
Nice. IMO the Kevlar is just as, if not more important, than the shape of the teeth. Thanks for the heads-up! |
| Author: | 900streetfighter [ Fri Mar 06, 2015 8:34 am ] |
Those BH belts have similar tooth to Dayco belts, with a 'groove' at the tip of the tooth. |
