| Rear brake light switch? http://ducatipaso.org/forum/viewtopic.php?f=3&t=6232 |
Page 1 of 2 |
| Author: | paulmozzi [ Fri Jun 21, 2013 2:05 pm ] |
| Post subject: | Rear brake light switch? |
Hi guys, I realized this morning while checking my bike out before going to work, that my rear brake light does not come on when I depress the rear brake lever. The light comes on when I squezze the front lever, but regardless of how hard I step on the rear brake lever, the light will not come on. I looked in the forum for other people that have had this issue, and I was wondering if anyone knows what a good part # is for the replacement switch. As always, thank you all for your help. You guys are the best! Have a great weekend. Regards, Paul |
| Author: | paso750 [ Fri Jun 21, 2013 2:18 pm ] |
| Post subject: | Re: Rear brake light switch? |
https://www.box.com/s/lctqs86c8pvnxjp965v9 |
| Author: | paulmozzi [ Fri Jun 21, 2013 3:19 pm ] |
Thank you for the parts manual Paso 750! I appreciate your help. |
| Author: | paulmozzi [ Fri Jun 21, 2013 3:48 pm ] |
According to my dealer, this switch is obsolete. I guess I will have to convert to another style. Anyone have good luck with a replacement switch on these? Regards, Paul |
| Author: | paso750 [ Fri Jun 21, 2013 4:24 pm ] |
http://www.ebay.com/itm/MOTORCYCLE-HYDR ... 06&vxp=mtr You`ll have to shorten the cables and crimp on blade terminals then this should be fine. |
| Author: | paulmozzi [ Fri Jun 21, 2013 5:24 pm ] |
Thank you again Paso 750. |
| Author: | higgy [ Fri Jun 21, 2013 10:26 pm ] |
I prefer when possible to send my dollars to Bevel Heaven or Ed Milch any switch with the proper thread size will do, expect to match the electrical terminations to suit |
| Author: | Derek [ Sat Jun 22, 2013 11:10 am ] |
Available from Mdina Italia in the UK |
| Author: | paulmozzi [ Mon Jun 24, 2013 5:46 pm ] |
As usual, to say that you guys are a huge help, would be an understatement! Thank you again. |
| Author: | paulmozzi [ Thu Jul 25, 2013 12:09 am ] |
Hey guys, I went to change the rear brake light switch tonight, and I had a question regarding the brake line that the switch screws into. Is it possible to unscrew the switch, and not have any brake fluid leak out? Before I unscrew the switch, I want to make sure I am not missing anything. I am wondering if I should put hose pliers on the line, and clamp it off. As always, thank you for your help, and advice! Cheers Paul
| Author: | Derek [ Thu Jul 25, 2013 8:51 am ] |
You could use the hose clamps and it will help but you will still get some air introduced anyway. It shouldn't need much bleeding and it's not a hard to do as long as you keep the reservoir topped up. |
| Author: | paulmozzi [ Thu Jul 25, 2013 10:51 am ] |
Thank you Derek. I am going to give it a go this weekend. I appreciate the help. Regards, Paul |
| Author: | paulmozzi [ Sun Jul 28, 2013 8:44 pm ] |
Hey guys, I took off the rear switch to change it out, and I noticed I only have one copper washer between the rear hose. I looked at the parts diagram and there is supposed to be two washers. Has anyone tried to put the switch back using only one washer? It was not leaking, but, I really don't want to find out the hard way. I see that the washers are now obsolete. What do you think? Regards, Paul
| Author: | Mc tool [ Sun Jul 28, 2013 11:23 pm ] |
Paul , you can get those copper washers from heaps of places , any hardware shop , engineering supply shop , automotive brake shop , Yamaha , Honda ............bike shops In a lot of cases the last place you look for Ducati parts is a Ducati shop . Copper washers (for drain plugs too ) , circlips ,fuel line , throttle grips , spark plugs oil filters ect ect are available from "other" places heaps cheaper than a Ducati shop. Ideally you should replace those washers every time you remove them .... but unless they look damaged ( scored or squashed ) I use em again
| Author: | higgy [ Mon Jul 29, 2013 1:45 am ] |
