ducatipaso.org • View topic - Fuel Pump Removal
It is currently Thu Oct 29, 2026 9:48 pm
 Post subject: Fuel Pump Removal
PostPosted: Sun Jan 26, 2014 11:30 pm
Any advice on what to do or what not to do to get the fuel pump & filter out of the tank without screwing things up? Appreciate any advice.
Jetdoc
 Post subject: Re: Fuel Pump Removal
PostPosted: Sun Jan 26, 2014 11:44 pm
- Remove the Tank Cap and Ring
- First Disconnect the Fuel Hose between the Filter and the Tank.
- Now the Hand in the Tank and push two flat clips togteher
Inside the Tank you can see the position of the clips in the round for the pump
Exchange all Fuel Hoses, it is easy now
RĂ¼diger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Mon Jan 27, 2014 2:29 am
Thanks for the pictures, makes sense now.
Jetdoc
PostPosted: Tue Jan 28, 2014 1:07 pm
If like mine its stuck fast then you may need to unbolt the securing ring from the pump (loosen is probably enough) to allow some flex/movement and then woggle it all around again to get it to move :lol:
PostPosted: Thu Jan 30, 2014 6:52 pm
When you put the pump back in, don't forget to hook back up and check the rubber overflow hose that goes to the gas cap ring. If you forget this, then when you fill'er up, gas will pour out your overflow hose on the ground until the tank empties to about 3/4. Yes, that's experience talking. :)
du907
PostPosted: Thu Jan 30, 2014 11:31 pm
+1 on gas everywhere
